IES Light direction
in New Users
Hello,
Please help with IES Lights in DAZ3d Octane Plugin.
I use a Plane Object from DAZ an made it in the Plugin as IES light. So far so good.
But how can I change the direction? I want to use it as a spotlight and want to change the direction of the light in all directions.
For example 45° through a room.
Thanks
You mean, rotating the plane, or changing the angle that the light leaves the plane? The first I can help with, the second, I can't.
Daz Studio apply IES profiles on the Z-axis (Light from front to back). In order to fix it, export to OBJ , rotate Xaxis ( -90° ) and apply the OBJ as a morph. The light will be from top to bottom.
