Hair Conversion
AllegraAllegra Posts: 405
Just a thought....will there ever be a hair conversion system for Gen2?....I know you can fiddle around, but a point and click no brainer?
    Most hair from Gen 1 should autofit fine.
  • AllegraAllegra Posts: 405
    I was thinking more about V4 hair;)
  • StargazeyStargazey Posts: 286
    I may be doing something wrong, but I find that using autofit with hair often gives some of the strands straight bits, rather than the proper curves, so I usually just parent it to the head. Depending on the figure, and the hair, it sometimes needs a bit of adjustment but it's not a big problem. Basically you seem to be able to use any virtually hair on any figure!
