Genesis 8 Male Model Has White Eyes
I load my model in and it comes up with white eyes. I added the eyes several times and they still show as white. Please see screen shot below.
794 x 626 - 313K
  • Richard HaseltineRichard Haseltine Posts: 111,363
    The eyelashes are also solid. It looks as if you have a display issue, causing transparency-mapped surfaces to lose their transparency - does your machine have an Intel GPU (graphics card) on the CPU and a dedicated GPU from nVidia or AMD? If so make sure that DS is set to use the latter - for nVidia that would be in the nVidia Control Panel, which can be launched from the desktop right-click menu, and for AMD I beleive it's in the Catalyst Control Panel, which is probably accessible in the same way.
  • The eyelashes are also solid. It looks as if you have a display issue, causing transparency-mapped surfaces to lose their transparency - does your machine have an Intel GPU (graphics card) on the CPU and a dedicated GPU from nVidia or AMD? If so make sure that DS is set to use the latter - for nVidia that would be in the nVidia Control Panel, which can be launched from the desktop right-click menu, and for AMD I beleive it's in the Catalyst Control Panel, which is probably accessible in the same way.
    Thanks for the help. I actually have a mac book pro that I am using. It's 32 core.
    Specs
    Macbook Pro (mid 2012) 2.5 ghz core i5 4 gb 1600 mhz ddr3 Grapx Intel Hd 4000 1535 MB.
    Any advice?
  • How would I set in on a macbook pro?
  • Cris PalominoCris Palomino Posts: 12,964
    As far as I know, you only have access to cpu on your machine and it only has 2 cores.
