Brandon *Note - Textures are built on the Genesis 2 Male Base UV and will work with any Genesis 2 Ma
PatroklosPatroklos Posts: 533
Does anyone know what this means?
Thanks
  • SylvanSylvan Posts: 2,719
    It means you can load any G2M morph (or character) and the Brandon texture will fit.
    As long as that G2M also uses an M6 UV.
    Hope this helps :)
  • Richard HaseltineRichard Haseltine Posts: 111,677
    It means you don't need to own any of the character sets, just the base G2M (no need for M6, or F6 or D6 or whatever comes next)
  • PatroklosPatroklos Posts: 533
    Thanks, I now understand
    good to know...I'm not buying m6 but I liked the Brandon character.
    I'm not sure if the morph is stand alone, but the textures should be by the description.
    I'm not sure if the morph is stand alone, but the textures should be by the description.That's alright it was the texture I was after...
