How much to comission a script?
Hi,
I came up with a method to pretty up some stuff in my renders. I'd like to put into a script/scripts and submit to be sold as a product, but I have no scripting experience and learning to sciript stuff from documentation and examples would take a lot of time I don't have at the moment. How much would it cost me to comission a script that I would later use commercially? Or to have someone walk me through making it myself?
It would have to do the following:
- create geoshell
- apply a shader from DAZ default resources to it
- change some object and surface parameters on the shell
And three smaller scripts to adjust it afterwards:
one to adjust the value of a surface parameter on all surfaces of the shell
second to do the same but only to surfaces with specific names from a list that the script would look for
and third to simply change one parameter
I would be paying with paypal and the rights to use the scripts would be mine.
Those appear to be fairly simple things to do - mostly a matter of selecting nodes and properties, and running the action to create a GeoShell. You may find a lot of what you need in the scripting forum https://www.daz3d.com/forums/categories/daz-script-developer-discussion (I was thinking there's been a thread ion adding a GeoShell recently, but the one I see if for a Smoothing Modifier).
