Using Fluidos Plugin
darkdrahethick
Trying to learn how to use Fluidos, which I followed the tutorial and got it to mostly work. I think I'm maybe missing the shader file or something. The beach I put in the scene doesn't render right and neither does the fluido water shader.
The image was rendered using iray and iray shader.
Thank you for any help or tips.
553 x 341 - 54K
Post edited by darkdrahethick on
You might want to check the PA's own thread https://www.daz3d.com/forums/discussion/273541/updated-to-v1-3-now-macos-support-fluidos-a-fluids-simulator-plugin-for-daz-studio-commercial#latest
Which shader did you use?
In the image, it is the shader that comes with the Fluidos itself. Some reason it turns everything white. Thank you for the link I posted on there.
