Low-Res V3 and M3
What's the polygon count on these products compared to the LoRez characters series?
https://www.daz3d.com/victoria-3-reduced-resolution
https://www.daz3d.com/michael-3-reduced-resolution
I'm wondering if these would work better for crowd scenes.
  • Dim ReaperDim Reaper Posts: 687
    Using Window > Scenes > Scene Info in Daz Studio, I am seeing:
    Victoria 3 / Michael 3: 74510
    Victoria 3 RR / Michael 3 RR: 24406
    For comparison:
    Victoria 4: 66830
    Default Genesis 8 Female: 65472
    I don't have the Lorenzo Lorez figure, but from the product page, it comes in between 5000 to 5500 polys.
    As for which would be best for crowd scenes, it suppose it depends on how big the crowd is, and how far away. From what I can see, the reduced resolution figures look better than the Lorez figures at a medium distance, and you have a wider choice of clothing, hair and poses from the generation 3 figures.  However, the Lorez figures are much fewer polygons and appear to have their own low poly outfits included.  I think that if I needed a big crowd scene, and I couldn't use any of the billboard products, I would likely go for the Lorenzo Lorez or other figures from that series.
    edited May 2019
    Genesis 8 is less that 20K, you must had subdivision on when you did the count.
    Post edited by Male-M3dia on
  • HavosHavos Posts: 5,705
    My advice is to use which ever Genesis figure you are most comfortable with and have the most content for as your background figures. Just ensure they are switched to base resolution, and their textures ( and clothing textures) are reduced to say 1024x1024 using a tool like Scene Optimizer. Textures use far more resources than polygons, and the heavily optimized Genesis figures will be far more flexible than using dedicated low rez figures like Lorenzo, for which there is very little content.
  • JamesJABJamesJAB Posts: 1,766
    edited May 2019
    G2F
    Base Rez - 21,556
    HR SubD 0 - 21,556
    HR SubD 1 - 85,253
    HR SubD 2 - 339,167
    G3F
    Base Rez - 17,418
    HR SubD 0 - 17,418
    HR SubD 1 - 68,000
    HR SubD 2 - 272,000
    G8F with Eylashes:
    Base Rez - 17,020
    HR SubD 0 - 17,020
    HR SubD 1 - 67,426
    HR SubD 2 - 268,558
    HR SubD 3 - 1,072,102
    Post edited by JamesJAB on
    Point taken - at SubD of 0 I get 16368 without the eyelashes, which would definitely be handy for background.  When I typed "Default Genesis 8 Female" I probably should have said "Genesis 8 female as it loads by default".
