Dream Home: Yard and Pool
Nyghtfall3DNyghtfall3D Posts: 817
I'm about to re-download the yard and pool. Which of these files do I need?
463 x 689 - 41K
  • TotteTotte Posts: 15,098
    First it depends on what program, but you tag said Poser so I guess Poser. Second it depends on platform, burt I assume Windows.
    So based on those assumptions, 8097_DHYardNpool_v1.1_dpc.exe.
  • Nyghtfall3DNyghtfall3D Posts: 817
    Thank you.
    You assume correctly. I use Windows. I'll update my tag with more info for future reference.
  • ruekakaruekaka Posts: 348
    I check always if the green buttons (for DIM) are available.
    These files should be the most current ones.
    The one marked with Legacy is for older Studio version (not sure up to which version).
    637 x 700 - 61K
    I don't use the installer, but that's an excellent tip, ruekaka.
    Thank you.
    Careful, that's actually the oldest version — there's a batch of 1.2 filenames at the bottom. Although the three in the middle without a .exe or .zip tag on the name are actually the most recent, they're the new DIM-compatible zip installers (and you don't have to use DIM to install them).
    This item is actually a bit of a hideous mess, all the old executable installers have been left in when they should have been removed, leaving only the new DIM files. If the names get confusing, they're the ones with both a blue and a green button next to them.
    Note that the process of converting stuff to the new format isn't finished yet — some things are still sitting in a "to-do" pile.
  • JGreenleesJGreenlees Posts: 2,249
    edited November 2013
    I will look into why the installers are still showing.
    Edited to add : the installers that aren't supposed to be there will be removed. in between 2 to 24 hours.
    thank you for letting us know :)
    Post edited by JGreenlees on
