How to cancel the Spot Render Tool?
Sometimes I use spot render into a new window to layer onto images. When drawing the box, I sometimes get the point of origin wrong, and want to start at a different point for sizing what I spot render.
So I usually try to shrink the box to the point where it won't spot render, and then replace. However, sometimes I don't actually shrink it enough, and it spot renders anway!
In short, is there a button or something to press to cancel the spot render box as I'm sizing/holding it? I've tried RMB for example, that doesn't work.
Thank you!
    I think the render must start before you can cancel, it can be a bit annoying when working with very complex scenes, for sure.
  • Sometimes I use spot render into a new window to layer onto images. When drawing the box, I sometimes get the point of origin wrong, and want to start at a different point for sizing what I spot render.
    Thank you!
    While you are drawing the box for the spot render click the right mouse button, that should cancel the render.
    Thank you!
    Nice one, thank you:)
  • LenioTGLenioTG Posts: 2,118
    Thank you!
    That's very true, I've discover it too by mistake the other day! :D
    It's the same when you move any slider, for example while adjusting a morph: just right click, and it won't change the slider position! You won't have to go back anymore. BTW, you can go back also by pressing CTRL+Z.
  • DefaultNameDefaultName Posts: 433
    Thank you!
    Oh Geez, now it works! I did try RMB before, but I must've done it wrong. Thank you!
  • The panel (box) that shows the render progress sometimes completely dissappears and won't come back. RMB doesn't do anything in this case. Its a program bug I wish someone would fix.
  • Are you sure it isn't just behind the main window because that was brought forward somehow?
