Using Poser Format Exporter to create a morph-injection?
Sand3
I'm having trouble trying to create a morph injection control for a Poser model. It seems to be successfully creating a PZ2 file that does precisely nothing. So... that's kind of a problem.
I've tried running the exporter several times, with "Transforms" and "valueparm" in various combinations of on and off, and when I open a fresh iteration of the character and load the PZ2 file, nothing happens. The character does not display any sign of the morph and the morph doesn't appear in the dials on the parameters tab.
I did a google search for making morph INJ files with the PFE script, and while the posts I found confirmed that it could be done, I couldn't find any instructions as to how.
423 x 699 - 132K
PFE creates pure settings poses - they need the morphs already present. If you have Injection Pose Builder and you are using the standard Generation 4 morph libraries you can feed the exported pose into Injection Pose Builder to create a full Inj pose, but if you are creating a custom morph then you are going to have to create the actual delta and visibility files - you can use exP Exporter to create a new ExP expansion, or if you have DS3 you can use DeltaX's morph tools to create files using one of the community channels in the figure.
This may help
How to use the Poser Format Exporter
http://www.daz3d.com/forums/discussion/6869/
