Invisible Roof
Hello, i made this in blender.
as you can see an invisble roof. i cant figure out what may have caused it.
it doesn't show in blender. only in Daz3d
please if anyone know how to remove it and how to avoid it in future.
thank you
https://i.ibb.co/zrp39Tr/Untitled.jpg
Post edited by riiteshyadav on
  • chris-2599934chris-2599934 Posts: 1,958
    I can't see anything. But that's probably because its invisible.
  • I can't see anything. But that's probably because its invisible.
    haha..
    Well i tried attaching file but somehow it didnt get uploaded.
  • Richard HaseltineRichard Haseltine Posts: 110,536
    How does it look in Blender? Does the missing roof show if you render?
  • Doc AcmeDoc Acme Posts: 1,153
    Roof or Cieling? Are you certain is actually NOT there?  Try placing your camera within the structure & look up.  Polygons have Normal surface so generally there only visible when viewed from one side.  A cieling would have it's normal pointing towards the floor but your camera is above it, in essense looking from the "back" side.
  • Syrus_DanteSyrus_Dante Posts: 983
    edited May 2019
    Check the Surface pane in Edit tab maybe there is a seperate material for the roof that has the opacity slider in the Shader settings turned all the way down.
    Had seen OBJs that imported completly invisible because the transparency/opacity inversion of values Daz Studio gets confused of all the time.
    @mdwhitney_17f0196a22 inverted normals show as black surfaces in the viewport.
    Post edited by Syrus_Dante on
