Genesis 2 Male Available for Download
DZ_jaredDZ_jared Posts: 1,316
Genesis 2 Male is now available for download through DIM and the Product Library. Just make sure you have DAZ Studio 4.5 or higher in your account.
«1
  • TheWheelManTheWheelMan Posts: 1,014
    edited November 2013
    Whoa! Thanks, Jared!
    Edit: Note to everyone. Search for Genesis 2 Starter Essentials, not Genesis 2 Male.
    Post edited by TheWheelMan on
  • ghastlycomicghastlycomic Posts: 2,531
    Woohoo. I guess we'll finally find out of Genesis 2 is REALLY a Genesis figure (ie. clothes and morphs are cross compatible) or if it's just V6 and M6. C'mon DOWNLOAD!
  • Three WishesThree Wishes Posts: 471
    Hum, interesting. I see updates for G2F Starter Essentials in the queue but nothing for G2M.
    Just lag in the publishing pipeline, maybe?
    Edit: N/M, just saw Wheelman's post.
    Post edited by Three Wishes on
  • DaikatanaDaikatana Posts: 830
    Thank you Jared!
  • scorpioscorpio Posts: 8,533
    Its not in my DIM but it is in my product library.
  • starionwolfstarionwolf Posts: 3,670
    I see Genesis 2 in my product library too. I searched for Genesis 2 starter essentials.
    464 x 463 - 66K
  • Sal UKSal UK Posts: 432
    Do he really think he would win dressed like that?
    1024 x 1024 - 786K
  • Faeryl WomynFaeryl Womyn Posts: 3,775
    The question I now have is about the head and body morphs I bought when G2 first came out, will they work properly on the male?
    I looked and no as far as I can see you cant, I guess its another morph set will have to be purchased.
    What the heck!!!! I just downloaded the G2F update and the G2M through DIM and it downloaded and installed but when I boot DAZ none of the Genesis 2 figures are in the content library. Anyone else having this problem?
  • barbultbarbult Posts: 27,497
    They both worked fine for me.
    I found the figures in the content library but the figures and their clothing are no longer in Smart Content. Do I have to go through and manually re add them all? Why would they do this?
    I surrender!
    XD
    Seriously, much celebratory dancing.
    Did you install while DAZ Studio was running? Try reimporting the metadata from Content Library Maintenance.
    No, Daz wasn't running.
    Grrr... dammit, I just knew this was going to be messed up somehow. These things always are.
    Nope. Reimporting metadata does not work. G2F and G2M will not show up in the smart content.
    Post edited by ghastlycomic on
  • frank0314frank0314 Posts: 15,100
    Do you see anything in Smart Content? If not see if your CMS is running
    Okay. Fixed it. I physically turned off Daz's Content management and then turned it back on again and now they're all showing up the way they're supposed to. Weird bug but all's well that ends well.
    Yeah everything else except G2F and G2M were showing up.
  • RCDescheneRCDeschene Posts: 2,817
    GYA!! The ONE day I DIDN'T bring my laptop with me! D:
    Oh well, at least now I have something to look forward to when I get home! :)
    I know nothing in life is certain....but I'm feeling pretty good about tomorrow.
    We shall see.
  • JabbaJabba Posts: 1,466
    Generally speaking, good stuff - it's the same-old-same-old when it comes to AutoFit, but even so there's tons of outfits that will fit no problem
    1500 x 1500 - 423K
    1500 x 1500 - 452K
    1500 x 1500 - 426K
    1500 x 1500 - 404K
  • kyoto kidkyoto kid Posts: 42,403
    ...hmm all I received via the DIM today was a Genesis 2 Female Starter Essentials update, not the Genesis 2 Starter Essentials. Had to go to the Content Library Page to get the Male Starter Essentials.
    Update.
    OK that worked,
    Cowabunga! He comes with Surfin' gear too.
    Post edited by kyoto kid on
    I'm confused by why the Phillip materials that come with G2M are categorized as materials for M5. Why aren't they categorized as being for Genesis 2 Male? The materials that came with G2F are categorized as being for Genesis 2 Female.
    well that was confusing. Saw there was an update for Gen 2 female in the Dim and the readme said "gen 2 male added". If I hadn't seen someone's post here that you ahve to actually search for "genesis 2 male", i woulnd't have realized he's a separate dwonload.
  • RAMWolffRAMWolff Posts: 10,382
    I don't have him installed yet. Can someone verify if the hands are the same position as G2 Female? Genesis 01 had the hands slightly clawed but the G2 Female is straight out. Also wondering how badly the Bruno for Gen 2 Female looks on the Gen 2 Male.
  • KatteyKattey Posts: 2,899
    I can verify that.
    Here is a picture, default G2M (back) and default G2F (front), zero pose for both.
    1657 x 665 - 133K
    Post edited by Kattey on
    Thanks Kattey.
    You have Bruno for Gen 2 Female? If so could you apply a few of the full body morphs? I know I had to compensate for the breasts for that area so wondering just how badly it looks.
    RAMWolff said:
    Thanks Kattey.
    Sure, give me about 10 minutes.
    Thank ya!
    Okie, there are some results. Because mesh for G2M and G2F is the same, I didn't use Transfer Utility but straight export-import. First time I did it as it is, second time I used G2F clone to deduct G2F shape from imported morph via reverse deformation.
    This is all G2M.
    First picture is Chunky 2, I believe, second should be Bruno Muscle 3, third should be Female Shape 2 or 3. On the left is straight import through Morph Loader Pro, on the right is import via reverse deformation/deduction of G2F from the morph, again through Morph Loader Pro. I'm not entirely sure which result you'd like to see at the end so if I've missed anything, tell me what sort of transfer you'd like to check.
    1800 x 928 - 189K
    1800 x 928 - 202K
    1800 x 928 - 186K
