Bridge Icon in 8.5?
timrishertimrisher Posts: 0
I am wondering what has happened to the bridge icon? I was using it in a function to create 3d walls of certain thicknesses by duplicating a plane and then bridging them. Is the icon hidden or changed? Thanks.
  • PhilWPhilW Posts: 5,162
    No, still there in the vertex modeller where it used to be!
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,505
    is it pro or standard?
    I have Pro, I'm not sure if that is one of the features that is Pro only. I am assuming if Tim used it previously then he will have upgraded to a similar version.
    By the way, to make a wall from a plane, you could just use the Add Thickness menu command, this is simpler and cuts out a step.
  • timrishertimrisher Posts: 0
    Thanks for your replies - I only have the standard Carrara. I upgraded, however from the 8 to the 8.5, and either I've done something wrong, or the icon was removed from one to the other. Thanks for the "thickness" command, though. I didn't know about it, and it is definitely much easier!
    I found this that does indicate that the bridge tool is a Pro-only feature.
    http://www.daz3d.com/products/carrara/carrara-tech-specs/
