Figure/character faces appearing much darker when rendered
Hello,
I have recently run into a specific problem in my latest scene that I wish to render. Whenever I click to render the scene, the faces of the figures/characters in my scene appear much darker than the rest of their bodies. Everything else is rendered just fine, but for some reason the faces of any figure/character I put into the scene turns several shades darker than the rest of their body. None of my other scenes have had this problem, and I am not sure why this is happening to this one in particular. I also don't recall using any particularly different assets in this scene that might cause this compared to my other renders. If anyone has any idea why this may be happening, I would greatly appreciate it!
  • Richard HaseltineRichard Haseltine Posts: 111,430
    I suspect you used an Iray preset on the figure (or it loaded that way) and applied a 3Delight material preset for the make-up (or vice versa).
  • tomodachitomodachi Posts: 22
    Thank you! Is there a way to remove 3Delight presets or see what presets I currently have applied?
