OH NO! Daz parametre window won't fit on screen and can't resize!!!
ghastlycomicghastlycomic Posts: 2,531
HELP!
I'm trying to do something but the window with the parametres I need won't fit on the screen and I can only resize it horizontally, not vertically!!! How do I get at the buttons and sliders I need that run off the bottom of the screen?
584 x 766 - 87K
  • ghastlycomicghastlycomic Posts: 2,531
    My resolution is 1366 x 768. This should be a high enough resolution to use the software as it always worked fine in previous versions.
    Seriously DAZ, they've had these things since 1995 called SCROLL BARS!
  • ShelLuserShelLuser Posts: 749
    Seconded!
    My pain is even worse than yours since I'm still an old fashioned user (or so I assume) who's using 1024x768 and still remembers the day that he bought the 17" TFT he's sitting after ("I've carried 17" CRT's around, isn't it amazing how light such a monitor has become?").
    Alas, enough of the semantics ;)
    But yeah, I've had the same issues ever since I discovered the 'Render editor' (control-shift-e on my customized setup, otherwise you need to select the Render menu and click "Render editor"). Same problem; a lot of options fell outside my screen and were hardly usable.
    However, one of the latest update(s) seem to have changed this behaviour a bit because now I got all the options fully visible whenever I set the dialog to be displayed maximized.
    Now, I've tried to reproduce you problem but I can't find that particular option. And well, I'm not experienced with Daz yet to recognize the option you're using, so I don't know if this trick may help you. However, when that render editor window always ran out of control and showed most of its options off screen I've always used Win-cursor_up to tell the window to maximize itself. So you press the 'windows button' and then press cursor-up.
    Another option, for example when you don't have a windows button, is to press alt-space. This will bring up the dialog context menu, which will also allow you to maximize it.
    As said I'm not sure if this helps you, as said; for a long time most options in the render editor also used to drop off screen, but it might help.
    And yeah; they should be using scrollbars!
    There is no maximize ability with the ERC property editor
    The only think I can do is switch my monitor into portrait mode then switch it back which is a real pain in the ass. Seriously DAZ, what gives? This function clearly worked fine in previous version of your software because I did it once before to create poses for my big eye anime morph.
    I've submitted a bug report. This is clearly an UNACCEPTABLE design flaw. There appears to be no other work around for it.
    Okay I decided to see just what the resolution of this window is by doing a screen capture in portrait more. Basically it looks like DAZ has decided if you have a monitor with a vertical resolution of LESS THAN 956 you can't use their software.
    If this isn't simply an oversight why the heck would they make that a minimum resolution requirement for the software. It makes no sense to have a resolution requirement that high when a lot of people use the software on laptops and most laptops have a vertical resolution of 768.
    317 x 956 - 56K
  • 3WC3WC Posts: 1,165
    Can you just dock the window? Then you should have scroll bars.
