Property Editor Pane is MIA
ghastlycomic
I can't find the Property Editor Pane. Have they changed things in the new version of Daz or has something gone horrible wrong?
I need to perform a ERC freeze and I can't find the place to do it!
1366 x 768 - 146K
Okay I guess they changed the layout. Property Hierarchy and the layout of the pane itself is changed too.
Of course now that I've found it I can't get it to work. Every time I try the program crashes and I get this error.
DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\QtCore4.dll" at 0033:000000006DEAC3B8, QEventLoop::exit()+8 byte(s)
Yes, it has changed in the latest release. The Property Editor pane (which previously took ages and ages to load Genesis) as been split into 2 areas. The first, which corresponds to the left side of the old Property Editor, is now called Property Hierarchy. The other, which corresponds to the right side of the PE, is Edit Mode in the Parameters Tab. You will be thrilled at how fast it loads now. For ERC freeze, you can reach it in two ways: First, open the Hierarchy Editor, find your morph in the searchable list, then right click and choose ERC freeze. Or, and this is my preferred method, find you morph in Parameters Tab, right click, choose Edit Mode (or choose edit mode through the dropdown menu). Once in Edit Mode, ERC Freeze is an option when you right-click on the parameter.
Just noticed there's another update to 4.6
So I'm downloading that and hopefully it will fix the crash.
Woot! No more crash!!!!
