Applying materials to Genesis 8 gens
lululee1lululee1 Posts: 346
Hi,
  I am working with geoshells.
I want to apply torso material from the geo shell torso to the gens.
I can do this by copying and pasting the torso material to the gens.
My question is do I apply those materials or other shaders to the geoshell gens or directly to the gens
on Genesis 8?
Hope this makes sense.
Cheerio
lululee
  • Matt_CastleMatt_Castle Posts: 3,289
    If you have a material copied from the geoshell, you almost certainly want to apply it to the geoshell's genitals material.
    However, bear in mind that the UV maps will not match the torso material by default, so if you have a UV-dependent geoshell, you will need to install an add-on that allows the genitals to use the torso UVs and then change the UV setting. (I believe there are free UV maps for the job, but I'm not sure where - I use some that came with Skin Builder).
  • lululee1lululee1 Posts: 346
    Hi Matt,
    Thanks so much for the info.
    I'm using Genesis 8 torso maps on the geo shell.
    The materials will be like shader so I don't think there should be a uv problem. (Hopefully)
    Cheerio
    lululee
