G8F expressions problem *SOLVED*
DarkendenDarkenden Posts: 30
edited May 2019 in The Commons
Hello, when I dial new expressions for G8F only the eyepulp and a little bit of eyebrowls move. The same expressions  work perfectly on G3F when I click them in smart content. The essention expressions of G8F works but all new dont work. How to fix this?
Post edited by Darkenden on
  • Richard HaseltineRichard Haseltine Posts: 111,792
    Are you using presets or manually setting sldiers? The description is unclear since you mention them working on Genesis 3 from Smart Content.
  • DarkendenDarkenden Posts: 30
    Ive tryied the both ways - just use presets to use them on G3. When I use the sliders on G8 there is no effect
    I reinstal the figure and the expressions pakc - the problem is all the expresion packs for G8 so the problem isn't in the packs. How can they work on G3 when using presets but dont work on G8 neither with presets nor with sliders - they affect only eyepulps.
    But they are made for Genesis 8? The proeprty names have chnaged, I think, at least to some extent so I wouldn't expect the same preset to work on both.
    So I think the case here is that I miss some face pose parameters that the expressions have to read and move - on the pictrures the components of the expresion is only eyelids and a few more. Can you tell me what to instal to have this components - I miss head parts pose controls - lips, nose, jaws, braws ect.
    1908 x 778 - 282K
    1918 x 831 - 306K
    1472 x 804 - 211K
    1366 x 797 - 191K
    1390 x 968 - 310K
    1380 x 916 - 243K
    If that's https://www.daz3d.com/ig-expressions-of-love-and-hate-for-genesis-8-female I don't see any indication that it requires anything beyond the base figure
    They work perfectly on G3 - all expresion products are like that not only this one. OK Im reinstaling everything may be.
    1800 x 728 - 218K
  • PetraPetra Posts: 1,157
    Are the expressions you are using on G8 for G3?
    No - it is the package from the above link. They are for G8F. Even if they are not, I have problem with all expressions for G8 not only this one pack.
    If you look at a picture 03 you will see the ERC [DELTA ADD] modification is only on brows and eyelids - I mean it shows that it wont work as expected. Someone know how to fix that ?
  • Valery3DValery3D Posts: 105
    Have you installed the Genesis 8 starter essentials? and if so did you install it to the right path on your pc? I always install my content via DAZ Studio connect and it then installs it the correct way.
    I've installed it with DAZ install manager. I even reinstall it - well now I installed it monual and all face modifiers appear and the expressions work FINALY - thanks all for the adviceses.
