Form Lines / Wrapping lines to use as reference for drawing
Hello, I searched the store for this but wasn't totally sure if I was just not using the right keywords or what, but I'm looking for textures or a plugin that adds lines that wrap around the forms of a figure so it's easier to visualize in 3d, which then makes it easier to use as reference for drawing.
Basically what Clip Studio's models has by default. I know Daz's models are much better, and I'm sure I'm not the first person who has thought to use them this way, so if it exists on the store, could someone point me in the right direction? Thanks a ton
I'm attaching an image to show what I mean. The blue wrapping lines. Anything like this exist for any of the newer figures? or any figure? Thanks again.
  • Charlie JudgeCharlie Judge Posts: 13,667
    Although not quite the same, there are wire mesh shaders available which may be of some use for this purpose:
    For Iray: https://www.daz3d.com/wireframe-and-hologram-shaders-for-iray
    For 3DL: https://www.daz3d.com/wireframe-and-hologram-shaders
  • RGcincyRGcincy Posts: 2,864
    This shader product may do what you want: Oso Shader Pack 1 for Iray
  • 3Diva3Diva Posts: 12,058
    edited May 2019
    @RGcincy is right, the Oso Shader Pack 1 works great for this, imo.
    Select Genesis 8 Male in the Scene Tab and in the Surfaces Tab select "Skin-Lips-Nails". Apply the "OB Simple Sketchy Squares" Shader.
    Change the UV Set to Easy Tiling.
    Change the tiling to Horizontal Tiles 5.0, Verticle Tiles 3.0.
    Here's the result (I threw some underwear on him to post on the forum, but of course you wouldn't need to do that if you're just using him for drawing reference).
    You can then save the figure as a Scene Subset and load him up anytime you need a drawing reference. :)
    555 x 151 - 24K
    405 x 234 - 28K
    377 x 221 - 23K
    554 x 720 - 235K
    Post edited by 3Diva on
