ds content lib maximum? the dreaded dsf not found message
MistaraMistara Posts: 38,675
edited April 2019 in Carrara Discussion
i recently hit 400gb content lib
loading something from it giving the dreaded dsf not found
but if i load from a small content folder it loads fine?
cant import frpm it either.  i wasnt having trouble at 300gb
is anyone else having trouble with a hugemongous my library ?
Post edited by Mistara on
    yjink quickest way to shave off 60gb or so by separating out the coifs
    my april and gold tassel folders huuuge
  • StezzaStezza Posts: 9,264
    edited April 2019
    mines a paltry 175GB so I can't help
    but what is a coif ?
    Post edited by Stezza on
    coif  hair do smiley
    either my first file restore corrupted files or system choked on gpt drive.  re-restoring to original mbr drive.
    so far havent seen dreaded dsf msg.
    texture folders not done copying yet. win doze saying 23 hours.
    the outhouse fully loaded. lol  been meaning to render it. line at the outhouse door
    the joshua tree kewl tree
    mann not gonna check my blood pressure today. so aggravating.
    my poser runtimes on gpt drive seem okay.  poser times only 100gbs, have a feeling the new 5tb is gonna wasted
    forgot to turn on gamma corr
    edited April 2019
    Strictly speaking a coif is :-
    1} A woman's close-fitting cap, now only worn under a veil by nuns.   The coif dates from the 10th century, and is a close fitting cap that covers the top, back, and sides of the head. It was usually made from white linen and tied under the chin. They were everyday wear for lower class men and women from the 12th to 15th centuries.
    However Misty probably means the secondary, more modern, usage..
    2) Short for coiffure. (A coiffure is a person's hairstyle.)
    Post edited by Chohole on
    yeah  coiffuresmiley
    i keep all the wigs under a coif folder
    clothes under couture
    textures folder still copying  doh
    tee hee outhouse.  hive wire dog doesnt need weight conversion.  but not face rigged.
    1920 x 1067 - 2M
    edited April 2019
    Now my pc wont boot at all if yhe 5 tn drive is plugged onto the mobo. Oh the pain. 23 hours to copy my contrnt lib to it.  It stopped working of a sudden with no thume ir reason. Sits at the enter bios screen but it ignored keyboard.  I inplugged the sata cable of new drive. She boots. Doh. At my wits end. These boots were made for walking.
    Radio on a roll. Clapton followed by creedence
  • chickenmanchickenman Posts: 1,202
    ensure your boot order in BIOS is set for your normal drive and not the new drive.
    i saw a thing in the bios to make the sata ports hot.
    i enabled it.  booted,  got passed the enter bios screen, then plugged the new drive cable in.
    so as of right now i have accsess to the drive,
    divvying the 5 tb into 3 partitions. hoping if all under 2tb  i can boot normal.
    I have a 1 TB ssd drive for My OS (MBT Partition) and a 4 TB drive (GPT Partition)  for Carrara stuff and other items.
    My Carrara Content folder as loaded by DIM which does not include items loaded into carrara folder on my C drive. This folder is 914 GB in size and I have no issues using it.
    ssd drives a bit out of my range yet.  would like a 2tb one some day.  heard stuff loads a lot quicker?
    i deleted the partitions and reformatted the 5 tb..  so far it's booting.
    don't quite trust it to move my content to it right away.
    i remember when new hard drives came with the screws to screw it in the case.  used to come with rails even.
    teensyweensy screws have a bad habit of falling to the floor where they disappear into a vortex of infinity.  never to be found again.
    goes to the same place as socks and dropped lancets?
    edited May 2019
    YOu can get smaller SSD's for a lot cheaper than the large ones.
    I just bought 2 250 GB SSD's for $40 CDN. they are to be sued as the OS drives for a FreeNAS installation using an old tower. With 5 X 4 TB drives for storage.
    The 1 TB are more like $150 -300 depending on the drive.
    Post edited by chickenman on
    i'm writing avi files.  need spacious space and faster cores
