Transfer utility; item falls off figure
Am going through a pile of obj files and playing with them to make them into usable clothing in Daz.  I fit them to the figure, go into Transfer utility, think I've got everything set up right, but when I hit accept it falls to its original position and size.  Any suggestions as to what I'm missing here?
  • LeanaLeana Posts: 13,516
    If the obj doesn’t fit the figure directly then you need to move and scale the obj so it fits the figure in default pose, then export the modified version as obj, so you have an obj which would load at the right place and size directly.
    Then load that modified obj and use transfer utility on it.
