I broke the DIM
Hello.
I was installing the DAZ 4.11 beta version on a new computer. I tried to change the installation paths in the DIM and the DAZ program (to use another SSD insteal of the default one). However i did something wrong changing the directories pats at DIM or DAZ and now i can't install any of my products. They are not even showing in the DAZ studio for installion.
I tried to unistall both DAZ and DIM to reset the installation paths to default but somehow after i try to install DIM and DAZ again they are still using the new paths i tried to use.
Any i dea how i can fix that? Or how i can do a reinstall without using the modifications i did?
Thank you
Have you told DS about the new content paths (if you changed those - you are initially talking about the application)? It's easy to get an extra folder added or missed out - I usually recommend chnaging the paths in one application, then using Rob's fre scripts to update the other:
update DS after editing paths in DIM http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start
update DIM after changing paths in DS http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config/start
