Need advice about savig prop with multiple objects(Solved)
donkere.roosdonkere.roos Posts: 0
edited November 2013 in Daz Studio Discussion
I need some advice about saving a prop created with multiple objects.
Like skateboards, bikes and so on.
I understand the save directory folders. That's no problem. Also single .obj are no
problem. But when I try to save multiple .obj's as one prop there is only one that's
get saved. Do I miss something. :roll:
Post edited by donkere.roos on
  • Richard HaseltineRichard Haseltine Posts: 111,666
    Moved to DAZ Studio Discussion as Developer Discussion is for scripting, though it's not clear if this is a DAZ Studio question.
    What application are you using, and what are you trying to achieve - OBJ seems an odd format to be saving in for many purposes.
  • donkere.roosdonkere.roos Posts: 0
    The .obj's are imported into daz Studio. When I Save them as a single prop for example swords or hammers File/save as/support assets/figure prop there's no problem.
    But when it needs more items for example skateboard (deck and separate wheels) only one of the items that's been selected is saved.
    Ah, you may need to save each as an asset then save the assembly as a scene subset.
    Ah thank you. Worked like a charm.
