Help on creating a glass shader
Cool BlueCool Blue Posts: 38
Hey guys:
My question is rather a simple one. How do I go about creating a glass shader, fore a vase I'm working on. Your advice and support has always been very helpful to me, and I appreciate your thoughts.
Thanks again
Coolblue
Michael.
  • KhoryKhory Posts: 3,854
    Simplest solution would be to go peek in freestuff. That way your going to have a foundation to work from even if you want to play with the settings.I am pretty sure that there are some glass shaders in there. Also be sure that you have a 360 degree environment of some sort in the scene and that the raytraced settings are high enough when you do the render.
  • Scott LivingstonScott Livingston Posts: 4,352
    Just came across these settings (from NeilV 1) earlier today:
    NeilV 1 said:
    Are you after shader mixer settings or standard DS settings .
    As regular DS setting I tend to use. I find as long as you have raytrace setting set to at least 4 in your render settings these look very good.
    Diffuse Color 108 119 134
    strength 100%
    Glossiness 95%
    Specular Color 200 200 200
    Specular strength 100%
    Specular Through opacity = on
    Ambient Color 225 225 181
    Ambient Stength 25%
    Opacity Strength 25%
    Bump Setting (to show if using a bump map)
    Displacement (to show if using a displacement map)
    Reflection Color 255 255 255
    Reflection Strength 75%
    Refraction Color 255 255 255
    Index of Refraction 2.00
    Lighting Model = Plastic
    Link to original post
  • SertorialSertorial Posts: 962
    I have been trying to create a decent glass preset with the DAZ default shader, but following your suggested settings gives me this. (doesn't look very glass-like)
    700 x 700 - 136K
  • FirstBastionFirstBastion Posts: 8,076
    Because there are refraction and reflection values you need to put the glass inside a room of some sort. also set your raytrace bounce to 4 in render settings, and have at least one light set to raytraced.
    And Multiply Specular Through Opacity should be off when there is no trans map.
    Thanks. i have in fact perfected this now and have found a modified version of the above settings works rather better. (for one thing, the IoR for glass is 1.5, not 2.0)
    Here you go
    Diffuse Color 255 255 255
    strength 0%
    (ie no diffuse)
    Glossiness 95%
    Specular Through opacity = off
    Ambient Color 225 225 255
    Ambient Stength 0%
    (ie no ambient)
    Reflection Strength 100%
    Index of Refraction 1.5
    Refraction strength 75%
