How Do You Use "Fantom" Correctly
I need to create a shadow with an invisible object. I've tried it several ways, but applying UberSurface Base and turning on "Fantom" is supposed to work, but when I apply the shader and turn on "Fantom," the plane I'm test still shows up in my render.
What am I doing wrong???
    edited April 2019
    Could it be you have raytrace enabled, so it still shows in reflective surfaces?
    Here is a sphere with OmUber applied, a slightly reflective plane, a skydome and a distant light.
    Fantom and raytrace enabled:
    Fantom on, raytrace off:
    800 x 450 - 249K
    800 x 450 - 253K
    Post edited by Sven Dullah on
  • Richard HaseltineRichard Haseltine Posts: 111,878
    edited April 2019
    You are rendering in 3Delight?
    Edit: closing this so we can keep the whole discussion in your original thread https://www.daz3d.com/forums/discussion/322716/is-it-possible-to-cast-shadows-with-an-invisible-object#latest
