How to create an electrocution effect in renders?
Joe827Joe827 Posts: 274
Hello. For some of my future work, I'd like to render a figure being shocked. What I imagine would be similar to a cartoon electrocution where the skeleton of the character is visible during the shock. I do have the M4/V4 skeletons, but before I set out an experiment on my own, I was wondering if anyone has already tried anything like this and would be willing to volunteer some advice to save me some time?
Thank you,
-Joe
    Lightning bolts.
  • Joe827Joe827 Posts: 274
    To clarify, I am wanting to create an illuminated/translucent effect on the body that allows the skeleton to come through. I have plenty of lightening bolt/energy props.
    There's the pw Effects plugin
    http://www.daz3d.com/pweffect/
    and the pw Ghost plugin
    http://www.daz3d.com/pwghost
    And then there's the whole bundle
    http://www.daz3d.com/pw-shaders-bundle
  • TheWheelManTheWheelMan Posts: 1,014
    Thank you,
    -Joe
    Those skeletons come with an effect to make V4 and M4 varying degrees of transparent so that you can see the skeleton conformed underneath,
    PWEffect has been my goto for most energy effects. The effects can be a little overwhelming without a lot of trial and error which is why I've asked if anyone has tried a similar effect before and can give me any hints to start with. Thanks.
  • Richard HaseltineRichard Haseltine Posts: 112,021
    You could create a geometry shell for the figure and apply pwEffect to that to get an overlay, with pwGhost or the transparency settings that come with the skeletons on the base figure.
    edited December 2013
    FYI, in case anyone stumbles across this thread in the future, I was able to get the desired effect by:
    1. Applying "Subsurface Gummy & Plastic Shaders" over top of a figure's existing texture. I used this to simulate the "inner glow" effect.
    2. Render
    3. Add "V4 Skeleton" to the scene and parent it to the figure. Decrease the figure's opacity to ~85-90% so that the skeleton can be seen a little bit.
    3. Render
    I then combined/blended the two images using GIMP. I've attached an example for reference.
    -Joe
    ________________________
    Updated: I removed the image because there was nudity in it. I've posted it on DA. http://desertlion3d.deviantart.com/art/Character-Bio-Glare-423044249
    Post edited by Joe827 on
  • zawarkalzawarkal Posts: 1,018
    cool, thanks for the info
    I had tried doing something once with no luck
    I will be trying this!
