Wastelander Outfit boots won't fit
vonHobovonHobo Posts: 1,715
Hi.
Quick question about the following product:
https://www.daz3d.com/wastelander-for-genesis-3-male-s
I am fitting the outfit to a Genesis 8 Male figure, and the whole wardrobe fits perfectly. The boots are the only item that appear weird, as if there below the feet.
I have tried everything I can think of but there are no adjustments for the boots, and when you "fit to Genesis 8 Male" and then choose originally made for Genesis 3 Male in the drop down, the boots get screwed up. The rest of the clothing works just fine this way.
Does anyone know of a workaround for this?? It's a really cool outfit but it looks ridiculous in bare feet. :)
610 x 665 - 310K
Post edited by vonHobo on
  • vonHobovonHobo Posts: 1,715
    edited April 2019
    Here is a picture of what the product should look like ...
    610 x 665 - 310K
    960 x 1248 - 211K
    I believe there is a foot pose applied to G3M that allows the boots to fit. Unless you have https://www.daz3d.com/clothing-converter-from-genesis-3-male-to-genesis-8-male you may need to hide the G8M feet, or work out how to convert the G3 pose to work with G8.
    Thank you Dragonfly! smiley
    edited April 2019
    That is how it should look on GM3, not GM8. Shoes have never autofitted well like clothing does. Even with the converter don't expect it to work all the time.
    Post edited by FSMCDesigns on
    edited April 2019
    Thanks FSMC. I usually don't have any problems with autofit from G3 clothes to G8 and I have purchased a lot of items. This is the first pair of shoes that doesn't fit properly. Dissapointing but I'll deal with it by just hiding the feet. I would use the converter if it had a manual on-the-fly script to use. I don't want to convert the whole wardrobe because, well, I tried to do that with poses using the pose converter and it did not work on all the poses. The manual on-the-fly pose converter works well though.
    I really hope if they release a Genesis 9 line, that the base pose is not different than G8. It would mean less headaches for poses and wearables, and I'm thinking clothes too.
    Did you try just changing the scene identifier from genesis 3 male to genesis 8 male? I find this usually works better than autofit.
    Even if G9 goes with the same base pose, it still won't mean better compatibility
    Thanks. I will have to figure out what the Scene Identifier is... wink and then I will try changing it.
