Darona, unable to thorughly hide feet
https://www.daz3d.com/darona.
If I use this, I can use the utilities to hide the feet, BUT some of the peices still poke through at the ankles or there abouts. ideas?
  • kenshaw011267kenshaw011267 Posts: 3,805
    Making the feet invisible doesn't work?
  • CoryllonCoryllon Posts: 294
    it leaves parts of them poking through the hooves. Presumably actually parts of the shin. hidnig the shin disconnects the leg from the hooves
    340 x 479 - 92K
    Are you using a V4 type character?
  • LeanaLeana Posts: 13,515
    The product seems to include an INJ/REM for the feet (so probably a morph), did you use that?
  • SixDsSixDs Posts: 2,384
    edited April 2019
    There is a ShinsThickness morph included that might help. However, my first instinct would be to select the boots/hooves or whatever they are and create a smoothing modifier. If applying the smoothing modifier doesn't solve the pokethrough all by itself, go into the Parameters tab with the boots/hooves selected, and set the collision item to V4, adjusted the collision iterations as required until the pokethrough is gone.
    Post edited by SixDs on
  • nightwolf1982nightwolf1982 Posts: 1,321
    Apply the injfeetINJ Pose included with the product, then use the Joint Editor to reposition the feet bones to hide the geometry that pokes out.
    1920 x 1080 - 607K
    1920 x 1080 - 722K
    I actually had a morph that allowed me to drop her show size to 0, that and a slight morph to the shin thickness worked. Now does anyone have a good way to make a transition section between the hooves and the shins?
