is a easy way to smoothly incline (ramp) a row of verts?
so like say a straight line in x of several verts.  if i translate the vert on one end to a point in y. is there a way make the verts in the middle evenly position y translate to the target on the end?
i guess like a bezier ?
    You could use soft selection. The strength slider gives you some control over the profile of the slope. Another option might be the bend modifier. Both assume that all the points are linked.
    tysmiley
    is like the simplest things need advanced workflow
