Loading a IRAY shader causes " Would you like to save changes to current scene before closing?"
I keep getting this error when trying to load an IRAY shader, in my case "Daz Uber"
I went into the log file and found this :"2019-04-16 10:35:13.921 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054"
Anyone know how to fix this?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    It certainly looks like an issue with the Content Management Service - the preset is being treated as if it were a scene. Are you seeing the expected content type flashes (Materials, Actor, Wardrobe etc.) at top-left of the thumbnails? Are the Category and Products lists in the Content Library working, and Smart Content, and the Presets tabs in property panes?
  • edited April 2019
    The Catagory and Product list are working, I've never used Smart Content, but the preset tabs in the property panes work.
    I've googled this problem but the threads that I found did not help my issue.  Before, if I selected a lamp ,for instance, in the scene then clicked on the Surfaces tab and selected a light bulb surface that was part of the lamp, for instance, , I could then go to the Shaders presets folder and double click on the emmission iray Uber preset and it would load into the light surface that I selected before.  But now I get the message I'm having trouble with.
    Post edited by cheznous2029_28ab1adedc on
    So other content loads correctly - you can apply a pose to a figure, for example?
  • So other content loads correctly - you can apply a pose to a figure, for example?
    Some poses load normally some cause the same message.  Most of the time I can get around the problem by dragging the preset to the item I'm trying to change.
    It does sound like an issue with the Content Management System.
  • PadonePadone Posts: 4,314
    This happened to me too a couple of times but actually I'm not able to reproduce the issue. It seems it was a temporary glitch for me. May be just closing and reopening daz studio helped to fix this.
    Ive loaded DS many times and the problem persists, How can I fix the Content Management System?
    I have no idea. Apart reinstalling that is.
    I don't use the CMS myself since I only do manual installations and use the standard content pane to access my assets. No "smart" content here since I don't need/want it. Also I only install the assets I need for the current project and switch the content library when I change the project. This helps a lot both reliability and speed in production. So may be my particular workflow helps to deal with this issue too.
  • MartialMartial Posts: 431
    i see the same problem sometime with clothing or shaders (DazStudio 4.11 last beta)
    if i got this message  i just dragging the cloth or shader to the scene
