Am I misunderstanding the DSON core installer?
I thought that if a product said it had the DSON core installer you could load it in Poser. But the folder I unzipped only has DUF files. So how do I load it in Poser? Or can you not? It is Night Lounge by SoulessEmpathy
    edited November 2013
    DSON is the file format used in DS and does not mean it can be loaded in Poser. Only products that have Poser companion files have been tested to work using the DSON Importer for Poser. The description should specify the importer.
    Post edited by Male-M3dia on
  • edited December 1969
    Ok thanks, I didn't realize that meant I still had to convert it. It wouldn't work at first, but it must have been the old DUF format.
    Thanks.
  • TheWheelManTheWheelMan Posts: 1,014
    There is a free script that will let you load DUF files into Poser through the DSON Importer without the need of Poser Companion Files.
    http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader
