Loading objects to Genesis
jodycourjodycour Posts: 137
I downloaded some new weapons from Dystopia after I select the genesis figure then doubleclick the selected new weapon it doesn't load it onto the figure, it doesn't appear anywhere at all!
Also I have down loaded City at Night and City blocks and it doesn't show up at all in any category!
City at night shows up on the Dystopia Category but it doesn't show any thing present to select!
Please help!!!
  • frank0314frank0314 Posts: 15,120
    Which pack are you talking about with the weapons.
  • jodycourjodycour Posts: 137
    Dystopian Weapons Cache 2
  • JaderailJaderail Posts: 0
    First Be sure your loading the PROP and not a Material File. It helps if in Prefs you set DS to show extensions.
    Second the weapons pack is not Smart Proped. You most Pose and then Parent the items yourself.
    Thanks for the attempts of help! I ended up uninstalling everything and reinstalling everything, then I found out that I needed Bryce7 to beable to use Dystopia city building stuff! Once I downloaded Bryce so far everything is working!
