What version of AutoCAD .dxf, dwg, and scaling works best with Hexagon 2.5.
sharpewing
I see Hexagon 2.5 allows you to import AutoCAD files (.dxf or .dwg ) into it. Or at least it looks like it does. I have not had any luck doing so. I have 2014 and can save to an earlier version. Also I cant tell if I need to scale objects up or down. Any advice would be appreciated.
Post edited by sharpewing on
check this out, there was something about a missing file in the Hex install a while back that affected dxf/dwg import:
http://www.daz3d.com/forums/discussion/10560/
Thanks for the link. The file is not there.
You can get it at http://www.4shared.com/file/23Y3yJG0/adinit.html
You will need to register at 4shared to be able to download.
Good luck - worked for me :)
Hi All,
I found here some discussion regarding Auto Cad, If you want more discussing & better solution, visit to the below link:
Cad Services:roll:
Format Conversion:roll:
It will be more easy to contact them and send your problem details to get solution online.
