Trying to find a Tutorial for editing/moving items
Kia ora
Trying to find a Tutorial for editing/moving items, in this case a belt
I have the Artemis belt on a chracter and wanted to move it lower on the hips and under the Woodlands Corset.
I tryed to use the edit Geometry and selected ALL BUT there seems to be no way to transform this belt up and down, any time I get a
transform gizmo it's on the floor and it may move BUT nothing else does.
Can I not select ALL in either Vert, edge or face modes and drag this belt whole sale down to the level I would like then scale or conform so it's not clipping?
Thanks in advance
  • Dont autofit the belt. Load the belt into the scene and then move/morph the belt around the figure and in the position you want it. Then right click on the belt, select change parent. In the list that pops up select the pelvis (not the hip) and then selectparent in place at the bottom of the list. This can be a very manual method and youll find that if you pose the character alot you will also have to make adjustments to the belt. Generally though, this can get you some really great results. Also works for just about anything, hair, props, etc.
