Bryce Export
Does anyone know if Bryce 7 will be stable enough in Mac OS 10.10 to open a model and export it?
If not then how does one access models built in Bryce for use in other programs?
    edited April 2019
    # Bryce 7 is Not currently compatible with OS X 10.7 and above. (this is stated on both the Product Page and the Tech Specs for the program.)
    Please take note of this Sticky thread at the top of the forum
    https://www.daz3d.com/forums/discussion/19948/info-for-mac-users-regarding-os-x-lion-mountain-lion-mavericks-yosemite-et-al#latest
    Post edited by Chohole on
  • HoroHoro Posts: 11,740
    Models built in Bryce can only be opened in Bryce and then exported.
    Maybe, 80% of Bryce 7.1 works just fine under OSX 10.11.6. If your object is stored in the Objects presets that will crash out when selected. The boolean convert works as well as the Object export  so if it’s in a scene file you should be OK.
    This is an image of a 10.11.6 converted object .OBJ exported from Bryce to Modo (I use a dual boot Mac that I also run OS X 10.4.6) .
    Good luck!
    1278 x 1046 - 354K
  • ed3Ded3D Posts: 2,653
    _one of the Good bits  of an Mac _ can have macOS and Windows and Linux
