Room Creator | Making 90 and 45-degree Wall???
Greetings all:
I purchased the "Room Creator" packages and have built a nice house, but I'm having problems where my walls meet. There is one 90-degree corner in the "Room Creator" package, but it's too long for my purposes and cannot be changed in scale without ruining the object. So . . . I need to make new corners.
I want to make a new 90 and a 45-degree corner.
I've exported the shortest wall (2.5) to Hex and have successfully divided it in two, but I don't know what to do next or if I'm even on the right track.
I need a seamless 90 and seamless 45, and the walls need to extend just a few "inches" from the corners, not feet as does the 90-degree corner provided in the package.
Can anyone help? I'd really appreciate it.
  • MaxHancockMaxHancock Posts: 227
    edited April 2019
    Sounds like all you have to do is select and move the one edge from 90 degrees to 45.  To extend the shape, select one side and move it outward.
    Post edited by MaxHancock on
  • dmorsedmorse Posts: 6
    edited August 2019
    There is a morph in the wall that will off-set it to make a 45-degree wall possible (or any other offset wall you might need...
    1058 x 703 - 93K
    836 x 841 - 409K
    Post edited by dmorse on
