My Genesis 3 F model has gone AWOL [solved]
For some reason, whenever I reload a scene containing Genesis 3 Female, she doesn't load properly. All I get is the primative boxes wearing her clothes and hair. This has only been happening for the past week or so, and it only affects G3F. Also, I can load G3F fine manually, she just doesn't show up when I'm reloading a saved scene.
Log file from reloading:
2019-04-11 17:36:04.960 *** Scene Cleared ***2019-04-11 17:36:13.017 WARNING: fileinput\dzassetdaz.cpp(1904): Could not find geometry definition: /data/DAZ%203D/Genesis%203/Female/Genesis3Female.dsf#Genesis3Female-1.2019-04-11 17:36:13.082 WARNING: fileinput\dzassetdaz.cpp(1349): Failed to create uv set!2019-04-11 17:36:13.082 WARNING: fileinput\dzassetdaz.cpp(1349): Failed to create uv set!...2019-04-11 17:36:13.841 Iray INFO - module:category(SCENE:IO): 1.0 SCENE io info : Loading module "::nvidia::asphalt" from "C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\nvidia\asphalt.mdl".2019-04-11 17:36:13.841 Iray INFO - module:category(IMAGE:IO): 1.0 IMAGE io info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\asphalt.png", pixel type "Rgb", 1024x1024x1 pixels, 1 miplevel.2019-04-11 17:36:13.842 Iray INFO - module:category(IMAGE:IO): 1.0 IMAGE io info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\asphalt_bump.png", pixel type "Rgb", 512x512x1 pixels, 1 miplevel.2019-04-11 17:36:13.952 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.2019-04-11 17:36:13.952 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!...then it continues with a lot more "Failed to create"...
I just reinstalled G3F Starter Essentials and it had no effect. Anyone have any ideas? I'm running DS 4.10.
Post edited by Kitsumo on
Found the problem. Apparently there was a duplicate (and corrupt) Genesis3Female.dsf in one of my base directories. I removed the path to that and everything works now.
