V4 clothes on V5?
DekeDeke Posts: 1,636
I can't seem to load V4 shadowdancer clothes onto a V5 genesis model. Any thoughts?
  • fixmypcmikefixmypcmike Posts: 19,739
    Does it not bring up the Autofit dialog?
  • DekeDeke Posts: 1,636
    It doesn't even load the item. I select the genesis figure and click o n the icon for the pants or shirt and the item doesn't even load. Grrrr.
    What is the exact filename and filetype of the item you're trying to load?
    It is the clothing ensemble of "LM Shadowdancer." So with the Victoria 4 model selected, I go to Victoria 4.....Clothing....LM ShadowDancer...and select the "SD Pants" or "SD Shirt" icons. Neither double clicking nor dragging into the scene works.
    Those are the DS material presets -- you need to load the items from Content Library > Poser Formats > [your content folder name] > Figures > LM Shadow Dancer. Then select the clothing and apply the DS material presets.
    Yep, that did the trick. Thanks.
