None of my expressions or expression tools have any effect on any model
I cannot seem to solve this problem. the expression tools show up in the menu's and sliders, but have zero effect.
i have the model selected. ive tried various nodes and surface selections to no avail
  • Richard HaseltineRichard Haseltine Posts: 111,397
    You say they show up in menus and sliders - which?
  • You say they show up in menus and sliders - which?
    picture is worth a thousand words
    1920 x 1080 - 852K
  • DxC09DxC09 Posts: 35
    I am having the same problem some models work fine others.. not so much the slider you can adjust it and it wont affect the model at all - exppresions only thing that moves are the eyes
    the only way or work around I've managed is to redo it with a model that does work but in the long run its not good at all! The problem is for V4 as well not encountered it yet with Genesis either
    The DAZ 4th generation figure used ExP morph system that allowed for nearly unlimited morphs to be added.  The morphs did need to be initiated with a batch file and then injected to the figure from in Studio or Poser.
    Sorry, I missed the reply with the screen shot. Another thing to check is that you have any required products - some expression packs are designed to work with a pre-installed morph set (which should be noted on the product page).
