Creating a Level Of Detail doesn't work
I've been using Daz Studio together with ZBrush for quite a while now and almost everything works fine. But when I try to add another level of detail for a figure, the figure just disappears completely when I select the new level of detail. What am I doing wrong? I subdivided the figure in ZBrush, refined the sculpt and added more details. When I use GoZ to transfer it to Daz Studio, it opens up as a new Subdivision Surface. Then I export this version as an .obj file and try to import it inside the Add Level of Detail function. I don't get an error message and everything seems to be working. But when I choose the new Level of Detail, the figure just vanishes. Does anybody know how to make this work?
  • Richard HaseltineRichard Haseltine Posts: 111,374
    Note that LoD is not supported in DS 4, so you may well find saves don't work properly. However, LoD is for adding lower resolution levels, not higher.
