Josie 6 renders white (solved)
Josie 6 doesn't render correctly. The OpenGL preview window looks fine. I am using her default skin in Daz Studio 4. I still have the same issue. My other renders of Josie look fine. Is this a Renderman SSS bug?
I found some error messages in the log file:
3Delight message #45 (Severity 2): S2069: the interface of shader 'C:/Documents and Settings/My user name/Application Data/DAZ 3D/Studio4/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl' is invalid
3Delight message #45 (Severity 2): S2051: cannot load shader 'brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface', will use 'defaultsurface'
wendy♥catz said:
it might be the renderman SSS bug
reopening studio often fixes it
306 x 610 - 56K
Post edited by starionwolf on
nevermind, I accidentally loaded the wrong .duf file. :red: I'm going to delete the bad file now.
