Problems with Export Gen 3 Male and Female
Helo.
I have a little Problem here. I try to export a Genesis 3 Female and Male into Cinema 4d.
If i export Whillis Gen 3 into Cinema i only got the Original Genesis 3 Male.
If i export it as a Obj, it works well at the most cases. But i need my Model as a FBX because i have Problems to setup the Weights.
Why does it not work ? If my Model has Armor or Clothing i just use the Option merge clothing into Skeleton. It works well but not the Modified Morph.
What should i do ? Has it something to do how i setup my Mesh ? I can either just Click on Victoria 7 or maybe Chandra the Mesh is good in Daz3d Studio but not in Cinema. If i just load the Gen 3 Mesh and pull the Modifyers it wrks good too. But only the Export makes trouble.
  • Richard HaseltineRichard Haseltine Posts: 111,816
    This sounds like an issue with the rules for exporting morphs - unfortunately I have no real experience with using FBX export, and none at all with Cinema 4D.
