Need help with head mophs
zaselimzaselim Posts: 13
Hi, how's evryone.
So i was making a character based on a real female model and noticed that i don't have some morphs options for the face so i installed "Genesis 8 Female Head Morphs" "https://www.daz3d.com/genesis-8-female-head-morphs"; and made my new character i was making and then a couple of more. Today i load my main female charcters's scene and noticed that her face has changed from
to
And when i remove the newly install morphs and then load the scene she reverts back to her old look, but the problem is i want those morphs and i also want my main female character remain as her original look and i don't want to edit her morphs again. I have her face morphs saved as well and i re applied the morphs with Genesis 8 Female Head Morphs installed but nothing changes which seems like her original morpgs are being over written.
My question is, is there a way to have her as her old self(face) while having the Genesis 8 Female Head Morphs installed without changing the sliders one by one again?
I will really appreciate the help. Thanks.
Post edited by zaselim on
  • felisfelis Posts: 6,504
    To the best of my knowledge these morphs shouldn't affect your character.
    But maybe, if you have started with a charavter that is actually using some of those morphs; then they will properly be dialed in when the product is installed.
    My suggestion would then be that you make a screenshot of the morphs in 'Currently used', then install the product and again look in currently used. You should then be able to find those "new ones" and can dial them back to zero.
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Do you get a missing asset error when loading the scene with the morphs installed?
  • zaselimzaselim Posts: 13
    I will check that out and post my findings here. I also have my character's face morphs as a preset and after installing the morphs prodcut when i load the preset onto the changed (2nd pic) face, nothing changes and it remains the same like in the 2nd but i will still check out what you said and see if sliders change after installing the morphs product.
    Nope.
    Thanks for your tip, after installing the morphs my old character did get - and + values in some of the new slider i got. I reset them to 0 and my old characters' faces turned back to their old selves.
  • barbultbarbult Posts: 27,501
    It sounds like you accidently resaved Genesis 8 Female with morphs dialed in.
