Shaders no longer floating
Mosk the ScribeMosk the Scribe Posts: 908
My shaders no longer seem to be freely floatable in C8.5 Pro - which means I can't simply drag from one multichannel shader to another. Any idea why this might happen and how to set it back to show multiple shaders at the same time?
thanks
  • PhilWPhilW Posts: 5,162
    I can't check right now but there is an option under the Windows menu (?) that says something like Full Screen View, this may have been accidentally activated, if you deselect it, I think this will solve your problem.
  • xmasrosexmasrose Posts: 1,409
    A big thanks PhilW.
    I had the same problem and getting unchecked "Maximized window mode" under the Windows menu did it.
    xmasrose said:
    A big thanks PhilW.
    Sorry for my garbled description but at least you found it anyway!
  • Mosk the ScribeMosk the Scribe Posts: 908
    Hmm - Still not working for me. I have two monitors on a windows 7, 64 bit system. If I click to go full screen, it puts carrara onto my second monitor. If I click again for reduced size, instead of freeing/undocking my shaders, it just puts carrara back to my primary monitor.
    Not sure when I lost the ability to undock shaders. Any other suggestions?
    edited November 2013
    Have you tried deselecting "Maximised Windows Mode" as xmasrose found?
    Post edited by PhilW on
