win10 task manager gpu always 0% .. anyone else ?
PadonePadone Posts: 4,209
It's just a couple of days that I use win10 and the more I use it the less I like it. When using Iray the task manager GPU usage is always 0%, while if I use gpu-z I correctly see 100%, so I guess it's a win10 bug. Is anyone else having this issue ?
Post edited by Padone on
  • Richard HaseltineRichard Haseltine Posts: 110,559
    By default the Task Manager does not display the right details to catch iray - if you go to the Performance tab and chnage one of the graphs to Compute_0, or CUDA if that's in the menu, you should see the correct value.
  • PadonePadone Posts: 4,209
    edited April 2019
    Thanks so much Richard .. if I select CUDA then everything works fine !
    @Padone "It's just a couple of days that I use win10 and the more I use it the less I like it"
    Wait until the next Win10 update deletes your Nvidia driver and installs a Microsoft version that won't work for Iray.
  • LenioTGLenioTG Posts: 2,118
    I use GPU-Z, it's great! :D
    edited April 2019
    no way .. of course I disabled automatic updates as the very first thingy cheeky
    edited April 2019
    deleted (duplicate message)
    Do you have a reliable reference for that, or is it just the standard internet tech hysteria?
     Well let's see, plenty of references in this forum. Oh yeah, personal experience with Win10 before I reverted. Then again you can take it leave it. No one makes you listen.
    What I meant is are there people actually saying that the not-yet-released April update deletes your NIVIDIA drivers, or is that just a general expectation that it will do something bad?
