What's in her eyes ?
I'm getting some strange dark circles in my lastest character's eyes. Looks like two objects overlapping ?
Could it be morph related ? I fiddled around and can't find the culprit. Anyone ever seen this happen ?
Render :
Seen from inside the face :
  • TsubaTsuba Posts: 78
    edited April 2019
    Neverwmind, I found the culprit, finally !
    "Celeste Head Base" over 40% breaks the eyeball.
    Or just mixing too many head morphs.
    Edit : No, it's Celeste. I tested with only Celeste Head Base and it breaks the eyeball above 40%.
    Post edited by Tsuba on
    I would put in a support ticket so they can fix this. In the meantime, you could try selectiong each eyeball and see if you can zero out the morph on just them.
    edited April 2019
    Thanx Michael !
    I tried selecting an eyeball and "edit>object>zero>zero selected item shape", which sadly didn't do anything.
    All I can do is take Celeste Head Base down to 35 % and use individual morphs to make up for the loss. (EDIT : 30%)
    Love your renders on DeviantArt, by the way !
    I've noticed this happening as well when the character is too far from the grid area. (xyz translate number too high (+8000))
  • LenioTGLenioTG Posts: 2,118
    Yes, that happened to me too! :D
    The scene I'm building has a character flying in space, so I have to move the scene around her instead of her around the scene. :)
