Lil' Scrap Boy long render time
I have purchased both the Lil' Scrap Boy and the Lil' Patch Girl recently.
I tried to do a render with The Lil' Scrap Boy at low-res (viewport setting) but the program just hangs and never finishes. It's consuming 1603 GiB of memory for textures, whereas the Lil' Patch Girl only takes 2 minutes to render and uses only 331 GiB for textures.
I used the same Viewport render settings for both figures, no lights or props, just the figure with the headlamp. After 5 minutes, I had to close the DAZ program which said it was not responding.
Is there some inherent difference between these two products?
I am using Iray for both at Viewport render settings. Nothing fancy. Just the figure with no lights or props.
I have attached the screenshots of DAZ Studio from both renders.
  • scorpioscorpio Posts: 8,533
    I don't have the female figure but the male figures render subD level is set to 5, which is pretty high, try turning it down to 4
  • Cris PalominoCris Palomino Posts: 12,964
    edited April 2019
    Or even 3. Each subdevision level quadruples all polygons with each level.
    Post edited by Cris Palomino on
  • vonHobovonHobo Posts: 1,715
    That makes sense. Thanks. The female figure is default of 4.
    I adjusted the scrap boy to 4 instead of 5 and it renders just like patch girl now. Very quick at viewport setting. Thanks!
