Wanted: Nice rabbits and chicks
As I prep for Easter, the only rabbit or chicken available are highly aged or cartoon.  sad
  • LinwellyLinwelly Posts: 6,070
    more than enough chicks on the store ;)
    but yes that would be cool.
    I know there is a hare on sharecg but its more toon as well
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    edited March 2019
    Did the rabbit die?
    Sorrry, dated reference about chicks and rabbits and pregnancy...
    I just did a quick google search, and you are correct, most of the hares out there are from the V4 era...
    Chickens look to be even more scarce.  I'm seeing the one by Noggin, but that's it.
    Hopefully there is something more recent somewhere.
    I guess Chicks and Rabbits aren't as cool as Dinosaurs.
    Post edited by tj_1ca9500b on
  • PsyckosamaPsyckosama Posts: 510
    edited March 2019
    You'd be shocked what you can do with OSO's fur shaders. Fuzzy makes up for a world if ills.
    My suggestion, pick that up, make a proper detail mask... and you're golden.
    Post edited by Psyckosama on
  • FSMCDesignsFSMCDesigns Posts: 12,858
    Well duh!
    If you just need some for static uses, Adam Thwaites has one his site for free.
    https://www.most-digital-creations.com/hare.htm
    Here is a chick
    http://www.lynescreations.com/lynesfree8.htm
    Not the best quality, but better than nothing
    Have tried Lyne's site
    http://www.lynescreations.com/lynesfree4.htm
    Admittedly still a bit long in the tooth,  but do have the advantage of being free.
  • ElgyfuElgyfu Posts: 279
    LyneCreations has some free chickens and rabbits.  They are older Poser models, but might be of use.
    I'd give Lyne's a try. I haven't used the chickens or rabbits, but I did use her unicorn (from her MilHorse Maps & Morphs) recently. The unicorn looked pretty good after just using the metallic gold Iray shader on hooves & horn & applying the base Iray to everything else.
    It may be old but https://www.daz3d.com/noggins-rabbit-and-hare is still the best option for rabbits, in my opinion.
  • JOdelJOdel Posts: 6,322
    The Noggins chickens include chicks. They need to be fuzzier, but maybe LAMH can do feather fuzz? Or some kind of furr shader or something?
