dson importer for poser the installercannot find the right path
HogyoHogyo Posts: 59
edited November 2013 in Daz Studio Discussion
hi friends
I installed yesterday poser pro 2014 (it was all installed in the recommanded way) on my PC
so I wanted to try this brand new feature.. the Dson importer
First I was desapointed not to find any documentation about it...
anuway When I tried with the install manager to download it from my account I had the message that it cannot find
Install Manager cannot find a required path. The installer for "DSON Importer for Poser (Win 32-bit)" requires that the installed path for "Poser Pro 2014;10;Pro 2012;9 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
1284 x 631 - 103K
Post edited by Hogyo on
  • HogyoHogyo Posts: 59
    I have specified the path to the install manager but I always get the same answer
    Hogyo said:
    hi friends
    1192 x 647 - 113K
    OK I'have succeded to install it now I must find out how to use it!
    1248 x 644 - 144K
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Are you using the 32 bit version of Poser? If that's 64 bit Windows then the path is the 64 bit version of Poser. Assuming that is right, it looks as if you have DAZ Studio installed so you need to install only the Poser companion files, to \Smith Micros\PoserPro2014 Content in your documents folder as I recall if you selected the defaults, and then in Poser you need to click the icon showing a folder with a + at top-right of the library pane and add the \My DAZ 3D Library in your public documents and/or the \DAZ 3D\Studio\My Library folder in your documents folder so that Poser can find the needed data files and textures.
    There is documentation for the importer here http://docs.daz3d.com/doku.php/public/software/dson_importer/start
    Yes thank you I had found the Documentation at last.
    But I reinstalled all the files (genesis starter) In the default Poser directory so I have everything in double here or there it's a mess!
