will 4:11 read my 4:10 prefs?
alan bard newcomer
finally got DIM and friends to cough up 411 and got it installed but it's not looking at my 410 prefs.
my work area is spread over 4 monitors .. do not want to rebuild all that and save again.
Any idea where to stick a copy of the ten prefs so eleven will use them?
thanks
Beta uses separate settings from the general release so that it doesn't risk to "pollute" it.
Fortunately there's a way to import your layout from the general release to the beta:
Go to this page: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/general_ui/copy_ui_from_channel/start
Download the script using the link at the top of the script box.
Open the beta and drag the script to the viewport, then you should get a dialog asking which version you want to import.
